My ND5XS doesn’t have a bluetooth antenna and it would be handy for me to use BT from time to time. I’ve tried to look for a new one but all I can find is the High Gain and original wireless antennas. Would either of these work for bluetooth and if not anyone know where I could get a bluetooth antenna?
Contact your supplying Naim dealer.
Possibly a stupid question, but have you checked that your ND5XS is the later version that has a Bluetooth input?
The Bluetooth antenna has a different size plug/socket on it, so neither of the other antennas would fit.
