I sometimes use the bluetooth on the Mu-so 2 to connect to pc/projector to watch videos. It was working fine until i updated the firmware today to 4.3.0.6408. Now there is a 2 second lag. I tried restarting all my devices but no luck. Does anyone have a solution or a way to roll back the firmware?
Yes, I have done this. Taken the plug out and plug back in after a minute. Same problem persists. This only started happening straight after the firmware update.
I think you might be on to something there. I’ve jira’d it into the system and will get it verified next week. If as initially diagnosed, we’ll fix it in a service pack release.
Google chrome doesn’t support low latency synchronised video+audio across two devices. For that a Google tv chromecast dongle is needed. Apple Airplay2 however does.
Last Friday (10.12), I’ve just received a brand new qb2. After initial setup, I updated it to the lastest firmware version. Since first usage, using bluetooth connection immediately notice latency issue. Did not know it was a firmware problem. Trying to reinstall everything on my laptop (Windows 10), I was so angry, thinking of returning the device. And finally, I found this topic. Waiting for the update, also for the qb 2.
Welcome to the Forums - you’ll find lots of help and advice here.
As noted, a solution is being sought.
In the meantime, a reminder that Bluetooth, although convenient, is the least best way to stream to your Mu-so.
The Mu-so 2nd Generation family - including Mu-so Qb 2nd Generation - also support Chromecast and AirPlay, Spotify Connect, TIDAL Connect and fully integrated TIDAL and Qobuz support. They’re Roon-ready, too.
All these options will sound considerably better than Bluetooth, and regardless of this short-term bug, we’d urge you to use any of these options ahead of it.
Just before Christmas the third party supplier who delivers this component provided a fix. It will go through the usual internal and public beta test process, and if all good we’ll release it as a v4.3.1 service patch release.
At the same time we’re going through all other customer feedback on v4.3 and aim is to sort out any other bugs or undesirables introduced in this release.
I am experiencing the same problem and I think it is critical.
Please update the firmware as soon as possible.
If it is not possible, please let us know downgrade the firmware.
I appreciate the need for beta testing (although this feature-breaking bug slipped through this process) but it would be great if there could be some commitment or outline of an ETA.
This is a regression and a pretty significant issue for everyone who is using Mu-so as a “hub” device.
