Quick Q. Using mostly TIDAL (could be using streaming from a NAS too perhaps) and have a possible trigger on a NDX (bargain) which Im currently evaluating. Is Bluetooth a must have for any reason? or mostly commodotive…
What would you use the Bluetooth for? If nothing comes to mind, it’s not essential for you. Easy peasy lemon squeezy…
If i rephrase it then. Is there any recommendations what to use bluetooth for on a NDX? Want to know what I may be missing out on…
Would stream podcasts from your mobile phone?
It’s a convenience feature for lower quality streaming from iPhones etc. I never use it.
Are you already using the NDX with Tidal? Some very early models can’t do this without a hardware upgrade, which means they are not as much of a bargain as they may appear.
Thanks for you inputs. Yeah its nativte Tidal/Spotify, guess atleast one of them should be around a long time…
I use Bluetooth to connect my TV (Panasonic) to a NDX2. I didn’t want another cable to my rack and it works pretty well.
