Thank you to many of your previous advises that got myself a Hugo 1 as DAC to ND5XS, I do have to say I enjoyed it very much from the wider soundstages and depth, though occasionally will switch back to the ND5XS directly to SN2 for the original Naim sound.
Currently have Nordost Blue Heaven BNC to Hugo and Tellurium Q black RCA to SN2, think the Nordost maybe the weak link, any suggestions maybe can try Nordost Tyr2 or others, or should I upgrade the RCA to SN2 first?
Mark Grant cables, many years ago when I owned a Hugo I took mine along and visited Mark (I live about 10 minutes away) and he matched up the RCA plug and made the appropriate RCA to BNC coax without breaking the bank
Thank you so much Simon, may I ask if the BNC cable is directional?
Simon, read your previous post that you have Hugo too, I use the IFI Power X adaptor and plugged into Isotek Sigmas, do you think it will gain any advantages using LPS?
