Here is a scan of my A5 sheet workings.
Years are down the left margin
Next columns are the prime factors for each year (helps to find early/late dates)
Followed by the earliest possible date
then the latest possible date for each year.
Finally a tally of the number of days between the two Magic Dates
I “looped” the gaps between dates to help keep track of what I was doing.
I only did the counting of gaps that looked promising.
The other side of the sheet has the years 27-55 and 96-00
Wow! That’s much more robust and thorough than my approach!
I guessed that there would be a 3 or 4 calendar year difference, say with 1 or 2 prime years and an invalid co-prime year in-between. A co-prime is the product of 2 primes, e.g. 43 and 2. I was lucky in spotting the 1097 days example since I started close to my real date of birth! I didn’t cover the whole century.
Yes, it was that string of three years 57, 58 and 59 where I noticed the first two were co-primes and the third was a Prime. And especially 58, with 29 and it not being a leap year. I had the 1097 for quite a while, but it took a bit of methodical work to ensure there weren’t any other similar combinations.
I would add that the process isn’t limited to just 4 coins.
It should work with 40 coins (in other words, any multiple of 4 coins, I think) provided the starting point is that half the coins are heads-up and half the coins are heads-down.
I’ve only tried it up to 16 coins and it impresses the grandchildren
You can do it with gloves on if they think you can feel the difference between heads/tails with your fingers - you don’t need to feel the difference.
As a party-piece with the grandchildren, I normally use 16 coins and wear a pair of gloves - they are convinced that I can feel heads and tails. Add in a few mumbo- jumbo words and, hey-presto …. they are amazed.
