I assume we all know the probability of winning the UK National Lottery ?
When it started, way back in 1994 (?) you had to pick any six different numbers between 1 and 49 inclusive. If those six numbers (regardless of sequence) matched the six numbers selected at random by the machine, you were a winner. The probability of winning was … well, you probably know … (?)
A few years ago the rules changed. You could now choose your six numbers from a wider selection of numbers viz 1 to 59 inclusive. Your chances of winning the jackpot therefore “increased” or “decreased” compared to the initial game ? and now stood at … well again, you probably know (?).
One mark for looking the answers up.
Two marks for having remembered them (no cheating !!)
Ten marks for providing the necessary arithmetic.
The first number is any of 59 different numbers, the second number is any of 58 numbers, etc., so 1/59 x 1/58 x 1/57…x 1/54. As the 6 numbers are picked irrespective of order, you multiply that by 6!, or 720.
2 Earth years I think. For each Earth year, Mercury and Earth are aligned with the original starting alignment. However Venus is on 1.5 cycle afters after an Earth year, and takes another Earth year to be on 3 cycles, in an aligned position.
There were 9 people in the race and your grandson came 4th.
I guess it must be possible to solve it intuitively, but I resorted to simultaneous equations.
Many thanks for all your teasers this year Don.
I hope all the contributors to the thread have enjoyed at least one or two of my teasers. I have certainly enjoyed the teasers posted by yourself and others.
And likewise, I hope that yet others, who may not have posted but might have been watching or playing along from the side-lines, have also enjoyed the thread.
Do NOT give this “Teaser” to your school-children or grand-children !!
The instructions (below) make it clear that for this Teaser, you MUST do the calculations in the sequence they appear. So, the top line of the teaser reads: 5 + 9 = 14: 14 x 3 = 42: 42 – 6 = 36
This is NOT the standard form of doing arithmetic where the sequence is always :
Using conventional arithmetic, the top line would normally be evaluated :
5 + (9 x 3) – 6 = 5 + 27 – 6 = 26
The teaser might confuse us, but please don’t let it confuse your school children.
Arrange one of each of the following four numbers (3, 5, 6, 9) and one each of these symbols X (multiply); + (add); - (subtract) in every row and every column so as to achieve the answer at the end of each column and row. Do the calculations in the sequence in which they appear. (Do not use the standard form of doing arithmetic)
Looks like you both fully understood the rules. Hopefully the WARNING that I posted didn’t appear
condescending. I have avoided using this sort of puzzle with my grandchildren for reasons that both yourself and no doubt Mrs R appreciate.
The instructions (below) make it clear that for this Teaser, you MUST do the calculations in the sequence they appear. So, the top line of the teaser reads: 6 x 9 = 54; - 4 = 50; + 7 = 57
However, using conventional arithmetic in this particular case, the top line would also be evaluated the same way. But, the rest of the matrix MUST be evaluated in the sequence in which the numbers appear. A few lines might give the same answer either way, but don’t rely on it !
Arrange one of each of the following four numbers (4, 6, 7, 9) and one each of these symbols X (multiply); + (add); - (subtract) in every row and every column so as to achieve the answer at the end of each column and row. Do the calculations in the sequence in which they appear. (Do not use the standard form of doing arithmetic)
We were bagging up a pile of 2p pieces today with the help of our young grandsons. They inevitably started playing and came up with the triangular patterns below.
Our older grandson, happened to mention he was practising sequences in maths at school. Why he picked ‘58’ is anyone’s guess, but I asked him to tell us the answer, and have retained the question as was !
