However, when I tried to explain this to Mrs D, she would have none of it. I was reduced to writing out all 36 four-digit arrangements of 0 1 9 and even now, she’s convinced there is some skull-duggary going on
Going back to arithmetic progressions in A level, I have developed 3 formulae:-
The number of squares on the bottom row, where pattern number is “n”, is 1+2(n-1).
Taking the “bottom pyramid”, the squares in each row ascend from 1 up to 1+2(n-1) in increments of 2.
The “top pyramid” contains the same number of squares, less 1.
Using the formula for sum of terms in arithmetic progression, the formula for total squares for the 2 pyramids resolves as follows:-
n(2+2(n-1))-1.
Pattern 5 would contain 5(2+2(5-1))-1 which equates to 49, which can be seen to be correct.
So, pattern 10 would contain 10(2+2(10-1))-1 which equates to 199.
Pattern 99 would contain 99(2+2(99-1))-1 which equates to 19,601.
Thanks Don. I should have simplified my formula down to yours. I just felt I wanted to keep the “audit trail” nearer to the traditional formula for sum of arithmetic progression.
Unless of course you have a “neater” methodology.
Going back to the 4 digit codes problem, I still can’t get my head around it
If we start with say the number 1234 there are 4! (or 24) separate combinations. If we then make the 4 a 3, ie the number 1233, we lose 12 repeated combinations. I can’t work out where the additional 24 come from? For the avoidance of doubt, I’m not doubting the correct answer - that is plain to see - I just need some help in understanding it.
Well, I did approach it from a different direction. Vaguely recalled from school days more than 60 years ago.
Basically I looked at the successive differences, eg 6, 10, 14, 18, 22 …
Then at the successive differences again eg 4, 4, 4, 4 …
This suggests the progression involves n^2.
I 'll see if I can explain how I derived the co-efficient 2, thus deriving 2n^2 and the ‘-1’ and post it. I might have to dig out my old maths books to describe things clearly. At the moment, the co-efficient and the ‘-1’ just seemed to ‘fit-th-ebill’ by ‘observation’
It makes more sense if you look at it as two separate pyramids.
The bottom row of the bottom pyramid increments as follows 1,3,5,7,9, which is exactly the same as the increments between square numbers. The increment between the increments is a constant 2, which is the derivative of a square number.
You can see that the number of squares in the bottom pyramid is 1,4,9,16,25, which is the pattern number squared.
There are two identical pyramids with exception that the top pyramid has one fewer square (only the bottom pyramid contains 1 square; the top pyramid starts at 3).
So the bottom pyramid has n^2 squares. The top pyramid has n^2-1 squares.
In total there are 2n^2-1 squares.
I hope the following description of my method helps. It is different to the way others have solved the ‘White Square Patterns’ teaser. And it reaches back to my school days.
My daughter asked me to do a test run of a “connections” type quiz prepared for some of her colleagues. Took it to the pub last night for our regular Third Friday of the month meet. There’s a zoom meeting runs in parallel with this via a laptop on a table (a hangover from lockdown) so we effectively had two teams.
Here’s the first (of two). You have to connect four items and if possible identify the theme for that connection.
