Hi,
Can I connect the USB port for BT headphone ?
Hi,
No, you use the 3.5 mm headphone jack… if you want to use Bluetooth (as opposed to headphones from BT presumably) then you will need an adapter of some sort on the output of the 3.5mm connection
