At home I use BubbleUPnP running on my Windows PC in Android emulator. I want to have the same functionality on my works PC but I’d rather not run an Android emulator (it slows the PC down and makes updates a pain). Is there a DNLA client control programme I can use on windows which will give the functionality of BubbleUPnP? Basically choose music and ‘send’ to the player (renderer). Renderer volume control would be good as well; just like Bubble.
Thanks but I was after a little more control. I’ve discovered MediaMonkey does it!
Looks like the MuSo is one step closer to the office
I use Foobar2000 to upnp files from a PC. Works excellent. There is a upnp output component, which needs to be installed.
