May i ask if the burndy cable used to connect between nDAC to 555ps dr is it the same as the burndy use for connecting between nac 252 and supercap dr?
You may. They’re not.
Noted n thx for ur reply.
You’ll need an XPS or better yet, an S-XPS Burndy cable.
