I have a CDX2 powered by an XPS via a Burndy Cable. I have just purchased an NDX2, but no XPS DR to go with it (that is for another year). However, if I end up not using the CDX2 is the Burndy Cable Ok to use for connecting the XPS to the NDX2, or do I need a new one? I am told that I need an S-XPS Burndy and I assume that the existing is not an S-XPS. Thanks for any help offered.
The Burndy should be fine - you can use either an XPS or S-XPS Burndy. However, is it an Olive XPS or a current look XPS (XPS2)? The Olive XPS should not be used with the Network Players.
