Burndy cabling
Have upgraded to a 555DRPS from an XPSDR; question: can the same Burndy cable be used for both PS’s? The 555DRPS didn’t come come with a Burndy.
Thanks.
I assume it’s for use on your NAC-N272, in which case, yes, you use an XPS or S-XPS Burndy with the 555PS DR.
Don’t forget that the XPSDR is supplied with a Burndy, so if you sell the PS you need to include the Burndy, or make it clear that the Burndy is not included and price accordingly.
Thank you all very much for your prompt responses.
