Does anybody know what Burndy I need for a Snaxo 24 ? Looking on the internet it looks like the 17 Pin Burndy is for the Snaxo but my Snaxo looks like it has 13 pins so not sure.
So would the 17 Pin be OK or do I need a 13 Pin ?
You are right, as your snaxo wont have as many power rails in it, say compared to the 3 way ones.
The cable is the same for all the snaxo and superline
You need a SNAXO Burndy. The 2-4 has fewer active pins than the 3-6 but the Burndy used is the same.
