Hi,
As the Supercap DR now is discontinued, will Naim still continue to produce the special Burndy used to connect the Supercap DR to a Superline?
regards
Hi,
regards
It’s a SNAXO Burndy. I think they’re usually made to order. I would guess that it should remain available for as long as Naim continue to make Burndy cables, but I’m sure your dealer can make suitable enquiries.
Thanks Richard, I will ask about this. It is good to know if I would buy a second hand Supercap DR for my Superline. Chasing the right cable second hand on an aftermarket would make it is less tempting.
regards
But… thats part of the fun…!!!
Always look on the bright side…!
