Hi all
I’m a Newbie to the Forum. I have a Naim DAC but can’t find the Link Plug that came with it. Could I use the Link Plug that came with my new NDX2 or are they different?
John
John, I’ve made a couple of edits to your post to ensure it stays within forum rules. In answer to your question, no, you’ll need the correct link plug - specifically for the DAC in this case. Be careful trying to use others as they may very well cause damage to the equipment. If you can’t find it then your Naim dealer will be able to supply one for you, or else there are some dealers who offer them online.
@Millsy999
Assuming you had the link plug previously I’d put some effort into searching for it as these link plugs are not cheap!
