You could try swapping the speakers over to see if the fault is on the speakers or the outputs. If the outputs, it’s probably going to need a service/repair.
Yep. Although I did have an issue where the wires that feed the light on the volume knob had wrapped around the spindle multiple times, making it impossible to control via the remote. I released these wires but I’m now thinking why the wires had wrapped around tightly in the first place. Apparently they are supposed to be loosely wrapped around spindle. But not tightly.
