Cable between 282 and Supercap DR
Good day.
Can someone please confirm the cable used to connect the 282 to a HiCapDR can be used to connect the same 282 to a Supercap DR?
The guys servicing my 282 don’t know, which is reassuring. They only have a SupercapDR with no cables so they asked me to send them my NAPSC (with its cable) and a HiCapDR and/or its cable, depending on your confirmation.
Thank you.
Yes, the SNAIC5 is the same. Goes between 282 Upgrade 1 socket and socket 1 on the Supercap. Link plug 2 stays in place on the 282.
Don’t I need 2x SNAIC5 to connect the Supercap?
In full configuration yes, but as you’re just using it as a Hicap replacement for testing, then only one SNAIC5 needs to be used as I described.
With just one Snaic5, you leave the upgrade 2 link plug in, exactly how it is with a Hicap. To get the full benefit of the Supercap on the 282, you remove the link plug and connect a second Snaic5.
Thank you gentlemen.
who’s doing the service ? Out of interest
Martin
Id have thought the napsc should have been serviced with the 282?
