does naim have a cable for this application?
guess it would be a 4 pin din to stereo BNC (or whatever it’s called)
the 52 is fitted with straight through boards on input 1 and i’ll be using the external phone pre.
You could try asking Dave at Flashback to see if they could make one up for you, or check with the Chord Company to see if they can offer anything, albeit this will have to be ultimately purchased through a dealer rather than direct in Flashback’s case.
Chord have supplied a 2 phono to BNC for use with my 52 and still being built phono stage. HTH.
thanks Al
strange there isn’t a naim option since so many of the pre amps have this configuration
i’ll check around for one
