Hi guys…
Thinking of putting Pipework insulation around the cables at the back to stop them touching the floor & each other…
Will this cause heat issues??
Hi guys…
I wouldn’t have thought so, but if you are concerned don’t cover the full length. E.G. cover say 2 inches, then leave a gap for another 2
No it won’t, but just put small ones in the places where you need to keep something apart
My girls love red and yellow
I only do as short as possible, a few cm, only in the places where they would otherwise touch. It’s a workaround for situations where the ideal way (hanging freely without touching) can’t be achieved, so I figure it’s best to keep to a minimum.
