In order to connect a nat101 tuner, SNAPS power supply and Nait 2 integrated, am I correct in thinking that I would use a 4 pin SNAIC between the tuner and snaps, and then a 4 to 5 din between the snaps and nait2? The 4 to 5 would only carry signal. Is that right?
Yes, that’s correct.
Thank you. I just wanted to check.
