Attempting to tidy up a several metre run of 4 cables comprising 2 x ethernet, 1 x Toslink and a WH Phantom speaker cable.
At a guess, I’d assume it’s ok to route the digital cables together (in same trunking?), while allowing some separation for the speaker cable. If so, what’s a reasonable gap for the latter from the digital trio?
I have 2 x Ethernet, 1 x sat cable and an hdmi cable coexist in a 30 x 15mm d line trunking. The trunking can be seen on top of the skirting board behind the speakers in the picture. The speaker cable is loose.
