Cable to connect 282/HiCap to NC250
Hi, I’m trying to determine which cable one would use to connect the equipment noted above.
Even though sending signal through the HiCap before sending it to the amp seems less desirable than sending it directly from the preamp to the amp, I think that Naim recommends coming from the HiCap, I assume for grounding purposes?
If so, this would mean that the correct cable is 10-0244 as opposed to 10-0250?
Hopefully someone can confirm, thanks.
You need 2 x DIN to XLR (L and R) from HiCap to NC250. I’ve done it previously. Had Chord make me up a pair of Shawline cables.
Yes the 0244 cables are what you want.
The Din cable is one 4 pin DIN to XLR from the 282 to the 250. Not 2 x DIN.
Incorrect - see here…
Somehow missed the NC part! My bad!
