The idea is to organize basic information about the cables
There is usually a lot of mystique and suggestion. And trial and error tests that are usually very expensive.
I am not a connoisseur but I comment as synthetically I think it. You will contribute and correct.
I thought of dividing the cables into 2 categories:
- the power supply and
- data (analog and digital)
And the problems also in 2 categories:
- Interference by magnetic fields and
- Parasitic electricity
Magnetic fields
Different electric currents circulate through all the cables that generate different magnetic fields. As we usually have many cables in very close spaces, these magnetic fields interfere with the conduction of data. That is why it is good that the cables have magnetic protection: the power cables because they generate the most interference, and the data cables to be less interfered with by the previous ones.
I understand that the cables do not improve the sound, but rather the protection prevents the sound from getting worse. In other words, the more protected, the less the worse, because it has greater protection against interference. If the cables were ideally separated so as not to influence each other, I understand that any material would be the same as long as it respects what is necessary in terms of impedance, inductance and resistance. But ideal situations do not exist.
Analog data cables are influenced by magnetic fields generated by power cables. It remains to be seen if the same thing happens with digital ones (ethernet, toshlink, etc.) I have my doubts.
The electrical network provides voltage to many appliances in our home that produce alterations in the flow of current. These alterations, being present in the power supply of the audio equipment, introduce what is called parasitic electricity that inside the operation of the sensitive transformers. Therefore, it is best to have a direct power line to the equipment and that there are no other electrical appliances in it. There are also parasitic current filters that go between the network and the equipment, cleaning the electrical current.
I understand that the magnetic shield of the power cord works for the previous point, but not for this one. They are different problems.
If someone had the necessary measuring elements to verify the presence of magnetic fields in the area of the cables and parasitic electricity, it would be objectively easier to diagnose problems and choose solutions. As we do not usually have it, it ends up being by trial and error, wasting time and money, giving rise to mystical speculation.
Thus we find comments from who bought a cable changed his life, and for another it was equal to nothing.
To this is added that finally the recognition of the difference is subjective through listening, which can be more or less sensitive and more or less suggestible.
Anyway. I listen to corrections, contributions, etc.
