Calling Airlink balanced transformer users
In my new home I am planning the electrical supply for the music room, and a balanced isolating transformer makes sense, with Airlink standing out as a brand several forumites happily use, also reasonably priced. A problem I have is placement due to house layout and space, likely not possible in the meter cupboard so considering where it might best be placed, which might even include in the music room itself.
For those with these transformers, how much acoustic noise does it generate, both when fully loaded and when idle? Easiest description is probably how close does your ear need to be before you can detect any hum or buzz from it with other background noise minimised? In addition, if you put your ear close to it on the surface it is sitting or mounted on is it audible through that (or if not possible to get ear there, please try ear pressed to end of a rigid stick or similar pressed to the surface)?
It would also be useful if you could identify the model you have, and what sort of surface it is on.
Many thanks!
Mine is the CBS3000UKMP. It is designed to go in the room and has 3 UK plug outlets. A BPS designed for garage placement would need to be installed by a qualified sparks and would need to have a 6mm or 10mm supply to the room you have your system in.
The only noise of any sort i get from mine is when it’s switched on, it makes a thump and a buzz for few seconds and then is quiet, no noise at all. The only thing that makes a very slight hum is my 250 DR and to hear it i have to get my ear right down next to it. HiCap’s make no noise. In fact the only noise comes from my speakers, as next door will confirm :grinning_face_with_smiling_eyes:
I would suggest you also measure the voltage, and if it’s above 240, then you might want to let Airlink know so that they can step it down to say 230. Higher voltages can increase hum
Thanks @kitfit1 & @GadgetMan. Options currently include:
i) BPS type in meter cupboard if i can find room, wired with 10mm2 cable to socket outlets in music room.
ii) Similar to i but transformer located somewhere between meter cupboard and music room, e.g. in loft but I’d need to check temperature limitations, or in a ventilated cupboard at end of hall above music room doorway, or in music room itself, 10mm2 cable wiring it to a dedicated CU in meter cupboard.
Iii) CBS type in music room near hifi electronics, fed from standard house wiring.
Iv) CBS type in music room near hifi electronics, powered from separate socket fed by 10mm2 cable from own consumer unit in meter cupboard.
The question in deciding iii or iv is whether with the balanced transformer a dedicated supply makes any difference?
According to @Dan_M it defo makes a difference. I asked him to swap his from dedicated to ring main and he didn’t like it at all. At the moment mine is on the ring main, but that will be swapped to a dedicated supply over Xmas. He has also done testing between the standard cable that comes with the Airlink and a Puritan Ultimate, the Ultimate wins by a long way.
I’m not going there!
Hi, they have some good information on the web site; from memory it was in the tips section and there is a straight recommendation to feed from a dedicated supply and distance it from your electronics, if possible.
They actually discuss hum and offer a money back guarantee if your mains supply prohibits quiet operation after discussing with them. They seem to be a really solid operation.
Putting together a constrained layer damping mount should be fairly straightforward and damping the chassis with Deadmat Pro or similar should take care of any low level residual noise if it’s mounted in a position where it may be audible?
Considering the pros and cons myself and as my listening room is on the first floor locating it presents similar challenges, plus DC (distortion) on mains is bad here.
I have said it all before. The Airlink BPS3000UKMP is a great piece of kit. Used in listening room for my Naim PSDRs only : 552, 500 and 2 x 555s.
So in terms of transformer noise on Naim power supplies. None.
So the Airlink itself generally no noise at all. Very occasionally some hum. You have to go up close.
I am in an area of overvoltage which varies between 243V and 247V. Since installing the Airlink there is much reduced noise compared to before.
More crucially the sound is more transparent. The cable provided with the Airlink was a bottleneck. The Puritan Ultimate at about £400 used for 1 m did the job. Don’t underestimate the cable.
I have been doing careful experiments with @Geko now for several weeks and I know what to look for and know my system inside out, back to front and upside down. So I know when a cable makes a difference, what it is doing and whether it works or not.
I have detailed this in mine and Guy’s cabling thread. So I am a boss on this. BELIEVE!
BD
:flexed_biceps::flexed_biceps:
Airlink BPS5120MP user here, installed in garage near meter cupboard on 10mm2 radial supply to Hifi.
Dead quiet and runs cold, not a hint of warmth or hum.
Best regards, BF
+1 for Airlink BPS3000UKMP here. Completely silent for me and situated about 2 meters from my classic system. Following on from Dan’s experience I just upgraded to the same puritan ultimate cable and can confirm the sonic improvement over the standard cable. I’m home alone and pushing the system pretty hard with no audible stress whatsoever. The purtian cable adds some impressive drive to things and articulates bass detail so much more than the stock cable did. Even my wife could hear the difference and she gives no sh**ts about hifi normally.
I am glad that the Puritan Ultimate worked well for you.
Thanks @Dan_M, @Bluesfan & @Devilinthedetail for the information on your various implementations. It seems that noise is not a limitation to placement, which leaves me with the decision whether to use BPS somewhere wired in and its output feeding a bank of sockets, or the simpler CDS approach in room. Wiring isn’t really much different as either way I do plan a dedicated circuit, and might as well go for the oft-recommended 10mm2. (If I go for CDS I could even blind test!) It will be a while yet before I do it, as I have some building work to get done and need first to find a good builder, but meanwhile I’ll be trying to decide location for it, and will speak to Airlink as whatever they have to say may help me decide.
@Protegimus good luck with yours!
According to my tolerant family, maybe too well. The temptation to turn up the volume is proving hard to resist, my Apple Watch just warned me that I’m in the hearing-loss danger zone :joy:
No improvements in the system would cause me to raise my listening levels as I already like to listen at realistic levels, though with rock music that is normally only near-realistic level, and I limit the time out of respect for my ears - usually only an album or rwo at that level in a day and not every day.
What is everybody using to take power to and from their bps? Mine has arrived with a power cord which will have to do to start with. I have a puritan classic that I could use from bps to my block. Not sure I can afford a Tyr2!
And…what difference does the BPS make to your system, dont keep us in suspense…
