Calling All Active Speaker Users, Which XLR’s to Use?
You will see from my profile that I connect my ATC 40A active speakers to my NAC332 preamp using basic professional Van Damme XKE XLR-to-XLR balanced cables.
At the time these cables were a pragmatic choice as it is difficult to get more hi-fi focussed XLR-to-XLR balanced cables in a longer length and at a reasonable price.
Having upgraded to a second NPX300 power supply, upgraded power cables and have Van den Hul XLR/XLR cables between my NSS333 and NAC332, I now feel the Van Damme XLRs between the 332 and the 40 A’s is the weak link.
The problem is that most hifi XLR to XLR cables are designed to go between source and preamp, and hence come in 1 m to 2 m lengths. Longer lengths (to travel to speakers) have to be custom built. This narrows down choice and increases cost.
I have been looking at Tellurium Q Black (and Ultra Black) and Vertere Redline XLR to XLR cables but the cost is prohibitive if you need at least 6 m lengths.
As this length of XLR/XLR balanced pair are a custom order, they rarely appear as ex-demonstration or secondhand.
I am interested to hear what forumites are using to connect their preamps to their active speakers, and any recommendations.
Ah, The Sound of Music to the dealers’ ears :wink:. Given the physics of balanced XLR’s and the absence of substantive evidence to the contrary I’m not sure what the benefits of more expensive cables might be………
Of course, I’m most likely just plain wrong :hear_no_evil_monkey::see_no_evil_monkey::speak_no_evil_monkey:
ATB, J
Indeed you may be right.
I have however read some reviews of preamp/active speaker XLR cables which suggests there might be some mileage here.
Hi Nigel,
Although I do not have active main loudspeakers, I do use long lengths 7.5m of XLR between streaming preamplifier and mono power amplifiers.
I use the Cordial range available from Thomann.
There is also an interesting set of tests conducted by Alpha Audio on RCA Interconnects which I have found very informative.
Try searching using “ Interlinks don’t do anything! Or do they? 32 rca cables analyzed”
One of the things that appealed to me about active speakers was the ability to put the whole ‘which speaker cable?’ thing behind me. I bought XLR leads with Neutrik connectors and Mogami 2549 microphone cable. They work well and are thin enough to stuff under the hearth. £60 well spent. Of course reviews will suggest that expensive cables are better, as that’s what pays the bills.
Fear not J, I am the master of ‘trying before buying’.
I am just fishing for ideas and experiences.
‘Do nothing’ is a perfectly valid option.
Wins today’s Star Prize :glowing_star: :+1:.
ATB, J
I use Audioquest Red River (2×5m lengths), which replaced the cheap Mogami(?) cables I initially purchased.
I got the Audioquests relatively “cheap”, due to a pricing anomaly on the vendor’s website (5m lengths were cheaper than 2m lengths iirc).
In my experience, I would advise trying better mains cables for your 40A’s first, irrespective of what ATC say. Replacing the supplied cables with Titan Audio cables gave an immediate improvement.
I may have commented on this earlier in this thread, but I don’t really suffer from “confirmation bias”, and so was fully prepared to not experience any change.
With my 40As I started with the XLR Mogami, I had the opportunity to try second-hand Wireworld Eclipse 8s they didn’t leave the ATC… the Mogami were very good but the WW was simply better!
You don’t need to spend megabucks on XLR leads. I would imagine there is nothing wrong with your Van damme cables but we all want the best for our systems. Designacable will make any length cable and I used 6m Mogami XLRs from them which were very reasonably priced and sounded very good. It’s only when a pair of Linn Silver 6.3m came up on eBay for 1/2 price that I splashed out. Couldn’t help myself :blush:
Indeed, I have already replaced the power cable supplied with 40As with MCRU No.75 power leads. Maybe not the best but they seem to work well with the 40As.
I don’t really follow the logic of thinking that XLR cables are somehow less important than other types of cables and that there’s no need to spend much on them. I would say that however much you spend should be in line with what you spend on any other cable. Why not? Why should XLRs be less important? They are signal cables so they matter IMHO. Chord cables seem to be a popular choice for Naim kit and obviously there’s a historical connection (no pun intended) there and to some extent a shared musical vision. In the absence of any suitable Naim cables or specific recommendations from Naim though you are flying blind really.
I am in the camp of better XLR do make a difference. Both Cardas Clear and now Shunyata Omega improved my system. I got the Shunyata second hand on Audiogon which softened the price blow.
I don’t think anyone has suggested they are less important. I think what many find is that you don’t need to spend huge amounts of money for quality XLRs. That’s not to say someone wont start are thread on this with head to head comparisons of exotic XLR cables costing thousands. :grin:
I use Gutwire synchrony cube 3 in 7m lengths, there replaced some mark grant cables. When i first got my atc 40a’s the dealer lent me some chord signature, I compared this to the mark grant (canare or mogami) and the very noticeable difference was an expansion in the presentation more 3d than 2d so to speak. They are however very expensive so i opted for the gutwire which do a very similar thing.
That’s what I meant. If that’s your approach to other cables, ie. RCA interconnects, speaker cables , mains cables etc. then it makes sense. But to say that it’s not necessary to spend large amounts on XLR cables when you are spending comparatively large amounts on other cables doesn’t make sense to me. Your tongue in cheek comment about XLR cables costing thousands seems to imply that you don’t think there’s anything to be gained from them. If there is something to be gained from costly DIN interconnects such as Super Lumina then I can’t for the life of me see why XLRs should be any different.
When I was active (Chord Dave DAC via balanced XLR to modified Behringer DCX25496 amps then triple XLR cables to Bryston power amps) I used DIY cables built from Mogami cable and Neutrik pro plugs with gold plated contacts to mate with the gold plated sockets on all components. The wire itself is typically somewhere around £3 per metre, and Neutrik plugs/sockets maybe £4-£5 each. If soldering isn’t your thing, as someone has already mentioned Designacable is one supplier that does ready made ones or can assemble to order.
I guess that is my approach to all cables XLRs in particular though as they don’t seem to have generated the same levels of discussion on this forum. Mains cables in particular generate completely opposite opinions. My view is that recording studios don’t seem to favour high cost cables and manufacturers like ATC don’t recommend them. Even Naim have been late to the game with Super Lumina favouring the likes of Chord Chrysalis in the past. Yes they affect the sound but the result can be very personal and a matter of taste. Find something that does the job for you at a reasonable (for you) cost and job done.
I bought my Van Damme XLRs from DesignaCable at a very reasonable price.
I am simply exploring if there are sensible upgrades out there that provide VFM.
Remember the days when we were all told that basic speaker and power cables is all we would ever need, including Naim themselves.
Now we have a plethora of posh speaker, interconnect and power cables. So why should XLR cables be any different? Indeed there are SuperLumina XLRs, which would be way too expensive for long runs.
Yes that’s a perfectly valid approach and nothing whatsoever wrong with it.
As far as recording studios go and other professional applications I don’t think any great inferences can be drawn from them not using expensive cables. It doesn’t mean that expensive cables in these applications wouldn’t sound better.
The professional audio culture is somewhat different to the domestic hi-fi one. Some people may take the view that “these are professional recording engineers and they know what they are doing and if they don’t think it makes a difference using expensive cables then clearly they are a waste of money”. But that misses the point. The culture is different, the criteria are different, the applications are different to domestic audio. A recording engineer would likely laugh at the notion of using something like Super Lumina speaker cable. They would likely use good old Van Damme studio grade cable. I don’t think most people would believe that Van Damme professional speaker cable would equal the performance of Super Lumina, or even NACA5 in a domestic system. So why don’t the BBC or Abbey Road use it? Short answer - because they just aren’t interested.
The culture is different. What they use is fine, tried and tested, industry standard and they are happy with it. That doesn’t mean that there isn’t better to be had. Neither does it mean that they don’t believe that there is better to be had.
But use whatever you are happy and comfortable with for sure. There is no requirement to use expensive cables.
