Need to speak to @Tehther10 regarding his NDX remote issue.
@LeeT You can use @Tether10 so a notice will prompt him when he signs on. Putting the @ sign in front of user’s name will alert them.
Just set up my Uniti 1 & used the NDX remote (which is identical) & the remote is working the Uniti 1 without issue so it seems it’s the NDX with a fault.
Sorted it
The connection directly behind the logo had come out of place slightly.
Remote now working the unit perfectly.
