Can a NAP 155XS power a NAC 202?
I believe the NAC 202 was designed to be used with the NAP 200 but wondered if the NAP 155 XS power amp would be able to power the NAC 202?
My plan would be to upgrade to a NAP 200 or 250 at some point in the future.
Thanks,
Jim
Yes, absolutely no issues with a 155 powering a 202.
Yep - that will work fine.
Thanks for the quick response!
And with the right speakers is rather good!
