I had a puzzling chat conversation with a support person on Verizon’s site. I have a Verizon Fios router and a Fios Extender. I asked if a NAS connected with an Ethernet cable to the Router or the Extender will be visible on my WiFi network. He said no it would not. That doesn’t sound right - specially if the NAS is wired to the router!
Very strange support person - I see my NAS over wifi on my Windows-10 laptop & up & down load & edit this way.
There is no difference in that regard no matter wifi or ethernet
The Core or other NAS would obviously need a wired connection to your LAN. From there you can have one or more wireless legs to other devices such as a computer to view the files, or an iOS device to control it. You can even have a WiFi leg between the router and a switch to which the Core is connected, and it would still work fine if the WiFi signal is robust.
Thanks. That was my thinking either. I think the Verizon support person on the chat line was just not up to the job. He had to consult someone three times when I kept expressing surprise at his answer.
Well I’m an Indian though in the US right now :-)! But I know what you mean. From the name he gave me he was an Indian and its obvious he was ignorant on the subject. Fortunately I’m a slightly more clued in Indian
If you are running windows and the nas does not show in the network section, this for me is not unusual.
Download something to check your lan IPs such as ‘Net Analyzer’ for iphone or android, then run it. It will return all your IPs on your local network, search through and your nas will be listed. Back in windows in the network section, in the address bar type two back slashes followed by the nases IP and it should show the shares, you can proceed to map those shares to make it easier next time.
I don’t understand what you mean by “this for me is not unusual”
I’ve been on Windows from the get go with my steaming, my NAS is always visible.
Screenshot shows File Explorer view, NAS in the Windows ‘Network’ section & also in the mapped ‘music (\NAS) (N)’
However its well documented that various SMB protocols and the constant updating of windows 10 can lead to some things simply not showing on the network even though they are there. Or showing but when clicked asking for passwords which were not set etc.
I was simply providing some assistance if that was the case on this this occasion.
I’ve ordered a Verizon Fios Extender and hope it works with the Uniti Core I intend to buy. If not I’ll have to to link it to the router and just enjoy the stronger WiFi on my upper floor from the Extender!
There is often a setting on the wifi configuration of routers which effectively isolates wifi clients from seeing other clients on the network and prevents other network clients from seeing the wifi client. For security reasons one may want to allow wifi clients to get the the internet but not anywhere else on the network. This may be what the Verizon guy was talking about and it may be a default wifi setting on the router, which could be changed.
Out of interest, why do you particularly want a Core? It won’t make better CD rips than your laptop and won’t sound any better than a decent NAS running Asset or Minimserver. It has inflexible metadata capabilities. It does of course have a fancy box.
