Maybe this is a strange question but… can I connect a Nova to a 300DR/282/HC/NDX combination? The amp abilities of the Nova are not required.
The Nova has a pre out which is intended to connect to a power amp. It’s possible to connect it to a preamp such as your 282, although with two preamps in the signal path it’s not ideal.
You can, but why would you?
Would be an interesting comparison the Nova>300 Vs Nova>282.
