Can I control my Uniti atom HE using Windows PC?
I know the answer to this back several years ago was a firm NO. But wondering if anything had changed. My use of the app on my IPad has been a bit glitchy recently. thanks, Bill
If you install bubblesoft UPnP server somewhere on your network you can use Linn Kazoo to stream from Qobuz or locally stored music and change the volume. That’s about 90% of what I use my system for so I’m happy to use Kazoo but if you want Tidal or Internet radio you’re out of luck.
Bubbleupnp will run internet radio via tunein. eg, this to my Auralic device. If your Naim device can use Bubbleupnp them you should be able to do the same.
The Beeb pulled BBC stations from TuneIn several years ago for listeners in the U.K. There are a few exceptions, Linn DSMs for example, but I don’t think BubbleUPnP server is one of them. There are always workarounds, MinimStreamer for example if you know the correct url of the stream, or perhaps a VPN, but wouldn’t a simpler and nicer solution be to get that iPad sorted?
Roger
Yep, would love to. Been messing with the iPad and iPhone since May, and still have issues consistently playing the music I have on a USB drive plugged into the back. The thing that bugs me is that it worked perfectly in April.
have you tried the local web client on it?
..http://ipaddress/webclient/
Audirvana supports UPnP and I was using it with the older 1st gen NDX without any major glitches, radio would occasionally drop but it generally stayed up for hours rather than minutes.
You can add the hls stream to tunein and then bubble upnp it.
You can install Android Studio. Its principally designed as a platform for building android apps on windows but functions as an emulator. From the emulation install naim app and off you go.
That being said if I was op I would be working out why my iPad is ‘glitchy’ because this solution will 100% not be less glitchy.
Don’t try this, it was withdrawn by Naim. It was never intended for public use and there were sometimes unintended consequences for those who tried to.
