Currently I have: Broadband Modem output cat6a to Asus Wifi Router RT-AC68U into the Wan Port. Then one Lan to a little 5 port switch the other Lan ports into the Asus for Nas , Computer, TV , cable box.
I want to move the WiFI router to a better more central location. Can I do the following:
Modem to Cisco 8 port switch, all the various items, TV, Nas Computer into the Cisco, then one longer say 6meter Cat6 to the Asus Wifi router?
The modem has to be connected to the WAN port on the router and everything else is connected to the router, either by WiFi or by ethernet cable to a LAN port on the router, via a switch if appropriate.
