I would like to make a shelf in my Fraim that holds the Naim Core, Power Supplies, Cisco and eR. This would mean putting the Naim Core on its side, so that the slot is vertical. Are there any issues rotating the Core so the slot is vertical? I would add some rubber bumpers to the side.
I would contact Naim direct.
It will work. Everything inside is supported properly and nothing sprung.
But the heatsink is designed as part of heat management system with hot air rising based on the horizontal pisition. It’s not like a Sony PS4 with dual axis heat management. You might well have issues there. I wouldn’t do it.
