I have an Olive NAP 140, NAC
72 and Hi-Cap plus CD5i and NDX. Can I use a brand new Flatcap for the two source components with the pre amp? I suspect not.
The HC and amp have been recapped within the last 18mths.
If not, what would you suggest to be able to use the Flatcap?
You can’t upgrade the CD5i with a PSU, and the NDX requires an XPS, so the Flatcap is no use to you here.
The 72/140 is a great amp, if it’s in good condition I wouldn’t change it for a Nait.
No options in your current system to add a Flatcap; but a Flatcap XS is near-brilliant with a Headline — it is what I have. Hicap is better, though, if you have the money.
Flatcap XS may benefit a CD5XS and/or a NAT05XS. Possibly.
