I have a new CD set (the Elton John Jewel Box), which has 8 discs. Uniti Core is finding metadata for 3 of the 8 discs, likely via MusicBrainz.
I see that iTunes has some basic metadata for all the discs.
Is there a way to export the metadata from iTunes and import that data into UnitiCore, as a starting place?
Thank you.
Hi, if you use iTunes (or possibly any other ripping software) on your computer to rip the CDs, you can save them to the Core Downloads folder complete with metadata.
You can’t change metadata on CDs ripped on the Core unless you make manual edits using the Naim app.
