I think the title is self explanatory, so can it?
I am going to add a Uniti Core to my system but am trying to keep the box count down, yet still play the odd CD
(System NAC-N272, NAP250DR, XPS, Focal Diablo)
No, I guess because there’s no point as it takes so little time to rip a disc to the Core, which should give better performance.
No, you need to rip the CD before you can play it.
Just curious. Why it’s different from the HDX, which could be used as a CD player too?
The HDX had normal controls on the front, and a remote so it was usable as a CD player. The Core has no controls or remote - everything is done via the App, so it’s a much better experience (metadata etc.) playing a file.
The N-Serve app can also control CD playback. The Unitiserve could do this too, but I never bother - it only takes 5 minutes to rip an album.
Do you delete the rip once you have played it and know you don’t really want to play it again?
No, I just leave it on the hard drive as I have enough space. Sure, there is a bit of stuff on there that I never really listen to but in the past my opinion of some music has changed quite a bit over time so I have the option of coming back to it.
