mik77
1
I disconnected my amps to change speaker cables and try to tidy cables behind my rack, and I have lost the plot on how to reconnect.
Can someone include a diagram of the connections?
I have 3 connections correct . 1.CD,2.Tuner,3.AV, LP12 with phono stage.
I think the connections between the 200 & 202 are wrong
The SNAIC4 cable that’s connected to Link 1 goes into Standard.
As an aside, you need to repair the cable going into “Link 1” as it appears damaged.
DG…
mik77
5
How can it as its 2 pin connection?
Link 1 is a four pin plug, upgrade 1 is two pin.
mik77
7
Yes that did it and all the connections are secure just the grommet/cover won’t push back in!
But all working now thankyou
