With Spotify I can cast from within the Spotify desktop app to my 272 or i.e a Chromecast Audio but for Tidal it’s a nogo using the desktop app. Does this work on the latest products from Naim such as NDX2, ND5SX2 etc?
I use iPhone, iPad and MacBook Pro and would like to get same flexibility as with Spotify Connect meaning I can stream with Tidal using desktop app, iPhone and iPad native Tidal app. Any third part devices that could solve this like Blusound Node 2i etc? I assume I will need to get something supporting Airplay to stream from Tidal desktop on a macbook? I want to avoid using third part apps like Naim, Bluesound etc and use Tidal.
Spotify has its own casting method, called Spotify Connect. This is supported in the legacy streamers and the current models.
Chromecasting is a new more generalised casting method developed by Google, that is supported directly in the new streamers only.
The last time I used the Windows Tidal desktop app it could only play to the laptop audio card or an attached USB dac. It has no casting functionality at all. I assume the Mac version is the same.
That would work I think, same as bluetooth. But the Tidal desktop app doesn’t have any functionality (Windows anyway). You would use the OS to attach airplay or bluetooth.
