I have tried a CERTICABLE NEW TECHNOLOGY CAT8 cable, directly from my CISCO switch to the Klimax DSM/3, but I do not hear any audible improvement compared to a standard CAT7 one.
Now my question is: Has anyone tried any CAT8 cable? What would be your opinion? Is it worthwhile to spend $,$$$?
Remember Cat6A cable type is for infrastructure wiring, and not optimised for patch lead wiring to hosts.
Standard patch wiring is typically Cat5e or Cat6 which is fine for patch leads, or infrastructure wiring.
Given that 40 Gbps Ethernet lines are used in the core of large high capacity data centre infrastructure fabrics, I can’t see much relevance for your home audio streaming network.
It’s a bit like powering your lawnmower with a Rolls Royce Olympus 593 turbo jet… for supersonic grass cutting,… your lawnmower would certainly sound impressive
Yes, I understand that cat8 is specially designed for greater bandwidth, high performance network, but there are quite a few folks out there claim that it can greatly improve the SQ of a high quality audio streamer, which I find a bit dubious.
Yes I agree, and I think such observations are based on stub loading and noise shaping which could occur on any cable type (the Cat spec becomes largely irrelevant) , you might even benefit using hand rolled Ethernet twisted pair cable… at Fast Ethernet it’s easy to do… surprised more don’t try it… some Kimber Kable, a vice and a hand drill, create two twisted pair runs… you could be well away and one could tweak and tinker to ones heart’s content.
But it is still interesting to hear the opinion of the people who are actually using cat8 or other expensive ethernet cable types? Do they really hear the differences? Is it a placebo or is it something that clearly improves the audio streaming network? If so, which one? Audioquest Diamond, Audioquest Vodka, WireWorld Starlight, Nordost Heimdall II?
On the opposite spectrum, I think there is a guy in this forum claims that he hears no difference between a wired ethernet and a homeplug connection.
Not using Cat 8 any longer as I preferred Blue Jeans Cable Cat 5e patch leads for flexibility and couldn’t hear an iota of difference (I use BT Connectix Cat 6a for my network infrastructure). Cat 8 from Supra was not very expensive and person who has it now swears it sounds better in his system. I use Linn DSM and Mac mini as sources and he has Naim NDX.
I also borrowed AudioQuest Vodka and found I couldn’t update my Linn DSM with it in place. A simple ping test revealed why. With BJC Cat5e patch leads there is no problem. I now avoid audiophile digital cables though no problems with Supra.
I did link to a report in another thread where listeners (double blind testing) could not tell a cheap out of spec $3 patch lead from AudioQuest Vodka, but a couple of forum members seemed annoyed by it. I guess try it and hear (or not) is the only way.
Would not surprise me in the least. I believe removing HomePlugs was a good move for me as some high frequency noise seemed to go away, but I may have imagined it. I don’t use them any longer.
There are some views from other audiophile forums that Ethernet cables play an important role in the home audio streaming, for example one guy in a prominent HIF forum started a topic “Throw Away Your Ethernet Cables And Audition Some Cat8 Ethernet Cables?” which is soliciting at least 1,129 enthusiastic replies.
I’ve gone from old sky ethernet cable, Amazon £5, Supra cat8, Chord C Stream, AQ Vodka (home demo), Chord Stream, Belden/Ghent, Chord Indigo and now the SR Atmosphere.
The most disappointing for me where the Supra (flat and lifeless) and AQ Vodka (overblown bass).
I tried with the Supra, Chord and SR setups to got loom into system as possible, as in power cables and all ethernet the same.
… I agree 1129 replies, but not enthusiastic. Some positive, some not, some asking questions, some drifting the thread up goat trails & some pointing out that that its not recommended by Linn
So Ethernet cables do have sound of their own? I am interested in ways to maximize the SQ of my system as I am using both MM+Chord Hugo1 and Linn Akurate DSM.
Only when coupled to a susceptible host system. TI produce a design white paper on how to reduce the loading of Ethernet cables and the resultant noise emission which will couple to host systems and typically produce an audible / noise shaping effect.
Thanks Simon, you’re really a wealth of info regarding networking, streaming.
I also suspect the build quality of the connectors probably makes some differences?
