What is the difference between socket 1 and 2 on a HiCap.
I ask because I need socket 2 repairing, (just a loose connection) and when looking inside, they are both linked up to each other. Is it an issue using socket 1 until I can send it to be repaired (my Naim dealer is still closed)?
I am not doing any DIY, I just wondered, as my logic says that the two are the same, left channel, right channel and ground going to socket (3 and) 4. I thought I would ask before trying it.
