I’ve just received my eBay Naim Nait 5si and have a question if that’s ok?
All is working well except the the CD bleeds through to all other inputs.
CD to tuner is about 50% volume, CD to HDD is about 5% volume but the worst is CD to AV. I have AV Pass-through enabled (I connect an AV amp to it for 5.1) and it come though at speaker shaking/damaging volume.
Presumably it’s bleeding though at 5% or so but then bypassing the volume and coming out at max.
Is this usual? … I know some bleed is expected at high volume but not this much surely? Naim Tech support didn’t know either…
I think my unit is about 17 months old and so has never had a service.
Thanks for the further info.
I will study the schematics for the Nait5si tomorrow to see if I can theorise why this may be happening.
Just to clarify:-
The bleed is happening on both channels?
The only connected sources are the CDP (into CD input) & AV receiver (into AV input)?
Hi NeilS - to clarify, I have a phono stage and a DAC connected to the other two inputs. Incidentally, I can play music from my TT or DAC and hear the CD at the same time!
For testing proposed, do you want me to remove the other sources?
