If I find I have a CD that skips, which is very rare, I use one of Russ Andrews’ ReVeel wipes to clean it. That usually does the trick. ReVeel is designed for cleaning CDs so no risk of accidental damage.
The Glass Wipes from Lidl are superb and will not damage the CD in any way, they just work.
Trust me. 50/50 water and rubbing alcohol works. I’ve done it and it polished out more than fingerprints and a CD which had errors now plays and can be ripped.
As previously mentioned, it’s what came with the CD/DVD cleaning kit I bought and it works.
One of the best products from a Lidl - even do a great job on specs and cleaning iphones😎
I wouldn’t use anything more abrasive than those glass wipes and alcohol/detergent/water sprays, I would be too worried about the laser mech being gummed up.
