CD Si or 5xs?
What you think, which one to choose new CDSi or twelve year old CD5xs?
Will any of these be good enough for Nait50 or will be better with NaitXS3?
I’d definitely go with the newer machine - it will work fine with either the 50 or the XS3 but be a better cosmetic match to the XS3
CD5XS has digital out option, if you want or need it. I bought mine ex-demo about 4 years ago. I love it.
Nick
Do you mean CD5Si?
The CD5xs is the better sounding machine as the CD5Si is the bottom of the range.
I wouldn’t buy Naim CD players having had 4. They are not properly supported anymore. In terms of support a brand new CD5Si can be bought new (12 months old or so).
Naim is out of the CD player game now, and support will be very limited.
5 year guarantee, though!
Yes, I mean CD5Si. I thought 3Si, Unitilite and Uniti still serviceable as they use Sanyo mechanism.
Does CD5Si give good sound being from the bottom of the range or it really weak?
I had it with the Nait 5Si and it worked superbly with that.
When I moved my amplification up a gear it sounded flat compared to other sources. And so I got a CDS2 with XPS.
But there’s quute a few on here who love the CD5Si.
I use a CD5si with a Nait 50 and it sounds superbly musical. Nothing obvioiusly lacking to my ears and I’ve had much more expensive Naim CD players in the past. Immediately before the CD5si I had a much more costly Moon 260D transport/Chord Qutest DAC. The CD5si very easily beats this. Far more musically engaging. In the context of much more expensive Naim amplification I’m sure the CD5si will quickly become limiting and you’ll need something better. But with the Nait 50 it works a treat to my ears. It doesn’t have the authority and gravitas of the more expensive Naim players but in this context it covers its tracks well and as I say there’s nothing obviously lacking. Not sure how it compares to the CD5XS but whatever it makes far more sense to me to get a new CD5si than a twelve year old used CD5XS regardless of anything else. Personally with the Nait 50 I would choose a new CD5si in preference to any used Naim CDP, however good.
Guess you mean CD5Si.?
The CD5XS is miles better, and with a Flartcap XS, its up there among the big boys.
CD5Si is developed from the original CD5i which wasn’t good to my ears. tbh other people like it so take a listen first, guess Naim still support that model.
Buying an old CD player coming with the doorstop scenario, ask Naim first for possible support before paying out.
Had Naim been able to continue support for their older players today, I’ve had kept my CD5XS/FCXS.
I use my CD5si with a Supernait 3 and have to say it sounds superb. I wouldn’t worry about the “ bottom of the range” comments, it’s still a £1400 machine. I have had mine for many years with no problems at all
Like I said it sounded spot on with the Nait 5Si which it was designed to partner. I thoroughly enjoyed it.
As I moved up to an 82 HiCap 250, I had an ND5XS with a non Naim DAC and the CD5Si didn’t sound as good.
It’s also what you are used to.
Look, it’s an excellent CD player but as you move up the range with Naim CD players it is not as good as others.
I’ve never heard an entry level Naim CDP with the higher amps but many years ago we downsized at the time from a CDS3 with 252/Supercap/olive250 and IBLs to just a CD5i-2/Nait5i-2 and nSats. I was shocked actually at how good that little system sounded. In some ways it was more engaging and fun than the bigger system. It didn’t have the authority and overall ability of the bigger set up but musically it was every bit as engaging. I think it’s a question of balance. It would be unrealistic to expect a CD5si to be so good in a much more up market Naim system but exactly as you say in the right context, ie. Nait amplification and suitable speakers, it isn’t found wanting.
Thanks to all for sharing your opinions. Never say never, but have no plans to move up Naim ladder, as my mainly source is CD and company has nothing to offer.
Might one day look at higher level system (CD + amplification), just a lit lazy to scan the universe for sound I will like, just I know I Iike Naim one :smiley:
It sounds to me that you are very very happy with your system. The Fraim, CD5si and Nait 50 and Nac A5 speaker cables paired with JBL speakers. Classic Naim system.
One of the things I loved about the CD5Si was the way the CD drive swings out. It is so cool looking.
I am sure that it sounds superb!
You mentioned the same earlier - however I understood you changed amplifier at the same time - ? .. so if that’s correct, you have no basis to say which component caused the improvement. If I got that wrong, apologies.
You’re right, I did change amps at the same time. But I know very well the sound of Naim CD players and Naim amps from very long experience of them, and also the sound of the Moon/Chord CDP and Moon amp. If I wasn’t so very familiar with this stuff then it would indeed be dodgy to conclude that the Naim CDP was better and further experimentation and listening would be required. But knowing the sound of this stuff as I do, and believe me the Naim CDP sounds entirely different in its presentaion to the Moon/Qutest, I didn’t need to do that. But yes, if you don’t know the sound of components very well indeed then you would need to do more work to make an informed decision.
Thanks Dan. It suits us now and TBH it’s much better than I was expecting it to be. Hence why I finally decided to get the Fraim really. I just felt that it was so good it deserved it and it would be a real shame not to max out the performance. Next stop - if we can get it done without too much upheaval - a dedicated mains supply. Will have to wait till next spring to investigate but if we go ahead I’ll be consulting you for advice on exactly how to proceed!
It’s a great plan Pete and in the meantime enjoy your wonderful system. You have made massive changes and it’s time to let it all bed in and just enjoy the music.
However you’d only heard other players which happened to have a Naim logo, never the one you’re using now. That’s not knowing it “very well indeed” by any measure.
Big fan of nSats here.
As I understand entrylevel Naim CD players were designed to run with their respective Naits (which is no longer).
Going higher with more revealing amps, might not always be successful - running entry level source.
Virtually the same with other brands, keep it simple and balanced or go full hog.
