CD5 + FLATCAP 2 troubleshooting
Got my hands on a CD5 + Flatcap which I want to connect to my NAC 202/NAP200 setup.
However, I can’t see to power the CD5 via the Flatcap.
Is someone able the clarify the correct cable connection please.
Thanks.
J
Do you have a the 5-pin DIN cable?
Here you go. You’ll need a SNAIC5 cable to link the two units together.
Does the CD5 work ok on its own (link plug fitted) ?
I do :+1:
The CD 5 turns on fine on its own via the mains cable.
So if you have them connected together, via a SNAIC5 as per the diagram, does it work ? You still need to power the CD5 from the mains, even with the FC2 connected - the FC2 is only powering the analogue output stage of the CD5.
Cheers James that diagram has sorted it.
Thanks a lot for the help!
That’s good. The CD5 is a fine player, especially when you have the FC2 as well. Enjoy :+1:
Getting Naim forum 2005 flashbacks on this one! :wink::joy:
Fond memories of my CD5/FC2, hope you get it up and running OK.
Up and running now thanks! Sounding great with my NAC 202/NAP 200.
Glad you have it sorted. I love my CD5, and having played a few CDs this evening, realise I don’t use it enough! And that’s without FlatCap assistance!
