My CD5SI suddenly stopped playing and the display shows 2 lightning dashes. The puck looks good.
Doesn’t matter which cd I put in the drawer, it doesn’t read the cd anymore. I turned in off and on and checked the cables, doesn’t help too. I tried to reset the player while holding the play (and stop) button while turning it on, but nothing happens.
The player is from November 2020.
Is there anything else I can try?
OK thanks. Just wanted to check that the little magnet that detects when the drawer is closed is still in place.
Unless someone like @NeilS has some other ideas, it does unfortunately sound like the mech has failed. It’s always a possibility with a laser mechanism. The good news though is that I would guess your unit is still within its initial warranty period, so i would get in touch with your supplying Naim dealer and tell them about the issue so they can arrange for it to be fixed.
