What is the best option to upgrade the interconnect cable from CD5si to SN3, currently using the interconnect supplied in the box with the CD5si. Suggestions appropriate to the value of the primary equipment please, so Transparent Magnum Opus are out!
Easy, stick with the one you have.
I agree with Gary. The lavender/grey interconnect may not look like much but you’ll have to spend a lot to better it, and then only in certain aspects. In others it is the essence of Naim.
