Any ideas why I’ve lost sound please? Disc is playing and amp is working thru other inputs. Just stopped yesterday.
Yes set to DIN 0. Have HiLine connected. If the the player has packed up would it just stop like that?
OK, that was a possibility, and worth trying - never had that happen in my experience.
Perhaps @Richard.Dane or others can advise?
Sorry in advance:
Hope your CD player isn’t (a) dead Laus
I’ll get my coat
If it’s definitely still set to DIN (check to be sure, just in case) then try it on another input that you know is working on the amp.
Try a power cycle.
Failing that, maybe @NeilS had some other ideas…
A long shot, but could it be the HiLine that’s failed?
Maybe trying another interconnect if there is one available to rule that out?
Like GeoffC has said i thought thats what had happened, i had the same problem and was puzzled but somehow i must have switched the input without knowing i had done it, hope you get it sorted without any expense.
If it’s a newer model - it hasn’t been switched to S/PDIF on the back when cleaning maybe?
Neil.
The CDX2 I once owned used to swap outputs by itself. I was in my dealer’s shop once when a customer phoned with the same problem. My dealer hadn’t heard of this happening before. I told the customer what to do and the problem was sorted.
Thanks. I’ll try all the above.
Sticky relay?
No, thanks, I’ve just had my pudding.
Thanks for all the helpful comments. A simple reboot was the solution.
Reboot = Power cycle?
(as a fellow CDX2 owner, I’d appreciate knowing any problems and all solutions!)
