It looks to me like the platter in my 2003 CDX2 is going a bit pale, especially in places where it curves sharply.
Fault? Feature? Problem? Should I sleep well tonight?
Thanks,
Mark
Thanks,
Mark
You could always apply some Just For Men. Maybe you have some already.
Be judicious in application, or the end result can look somewhat . . . forced.
I’m delighted to report that I had to google Just for Men to find out what you were referring to. Having now found out, it’s definitely a case of ‘I’m good, thanks’. It does look quite grey compared to the outer case, though, so there’s a good point hiding in there.
Less facetious responses to my query are also welcome.
Mark
How old is the player?
I dont have a history with Naim cd players, but plenty of plastics change color over the years. Color fading is a well understood phenomenon, and caused by a variety of factors. Heat can be one.
Mark, it looks OK to me - I think as long as it’s working well I wouldn’t worry about it.
17 years old (as per original post!).
Thanks, Richard - for all the attention I’ve paid, it might have been that colour for a while and I just noticed now. Maybe it’s the greyish daylight streaming into the room through the clouds today. It certainly works absolutely fine, but I just wanted to check with those on here who have a rather wider experience of Naim CD players than I have, just in case.
I’ll stick a CD on and enjoy the sound.
Mark
Gosh, mines been like that for years. 2002 model. Never given it a second thought.
Mind you as I think it’s the source of my sound woes maybe I should.
2005 model here for ref. With/without flash for colour fade / white balance comparison…plays, excellent
Both later VAM1202 versions.
The original VAM1250 had a light grey platter. Here’s a picture of the insides courtesy of Kuma. As you can see the VAM1250 platter is light grey in colour…
A good point - mine is definitely VAM1250 so good to know the earlier platter was lighter in colour. I’ll definitely sleep well tonight.
The CDs I listened to sounded great, by the way, as always.
Mark
