I just got my CDX2 back from focal-naim for a new transport, and I have this problem. I am opening a new ticket with them, but would like to see if anyone here ran into the same issue:
The Table of content (number of tracks, total time of the disk) is stuck on the first disk I put in, when I open the draw the display still shows the info of the disk vs “–”; and when I put another disk in the player doesn’t seem to read it and continue to display TOC of the first disk. It will play the new CD, but only if I play from the beginning. I can’t select any other tracks.
Sounds like you’re definitely on the right track there Richard, but either the magnet is stuck to the tray, or the circuit/reed switch has failed closed. Otherwise the laser diode would be permanently off.
Thanks, Richard. This is what I suspect after trying a few things without success, it’s as if opening/closing the drawer has no effect or the player is not aware of these actions. It plays cd fine, but can’t skip to random tracks because I guess the TOC was not read.
Thank you guys for the insight, and you are right on the money. Here is reply from Naim:
“The CD Tray door has a magnetic trigger that is used to tell the player that the door has opened and re-closed, he believes that it may have been dislodged during shipping.”
