Hi I’m a newbie and just started ripping CDs on my Uniti Star…as anticipated some are missing the cover art. Using the NAIM app on Android I’m able to locate the missing cover art but am failing to get the selected link picked up be the app. I’ve also tried downloading the images but when attmepting the gallery option it states no supported application.
I don’t use the android app, but in the IOS app with UnitiCore, which has similar firmware to the UnitiStar, you have to copy the selected image by tapping the desired image and selecting that option. Then you can back out of the image selection. And remember to “save” as you leave the editor.
My Android Phone is a Pixel 6 running Android 13…the copying the link deosn’t seem to be picked up in the Metadata app. I installed the Naim App on my old Chromebook and have been able to change the cover art as directed.
