Before I start, if I remove a label, can it be re-used or is it bin city…?
On both 82 and 52, the buttons have legends on little blocks. These can be heated with a hairdryer until the glue softens and then you can gently prise them out (I used a kitchen knife). After swapping them around to suit, letting the glue cool hardens it nicely.
OK, thanks Nick… I’ll have to get my mam to bring her hairdryer around tomorrow…!!!
I use needle point tweezers under one corner of the label. You may even not need a hair dryer (I’ve never had to use one). I take it you have “the sheet” of labels? The removed labels get put back onto the sheet, where they will stick, ready for use “next time”
Also applies to a 102.
